  • 14 Vote(s) - 2.64 Average
immobiliser trouble plz help
hi there im new to this site i have a t reg berlingo van 1.9d the van was great untill yesterday i tried to put a after market cd player in no wires chopped just straight connections then after when i tried to start the van it wont start the immobiliser on the dash was flashing and the van wont start is there any round this as i really need this for my job Sad
I'd strongly suggest checking your fuses, right of the steering column.
hi andre what would it be something to do with fuses that causes immobiliser to come on
It is worth checking for a potential quick fix. You could also try a BSI reset procedure:
Code:
Before sending the unit try the BSI Reset procedure as this may cure your faults:
Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
Ensure all doors are closed and remove key from the ignition.
Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds.
Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.).
Switch on the side lights through the driver's window.
Switch on the ignition and check system's functionality.
Hold lock button on key down for 10 seconds.
Remove key open & close door test central locking system.
Start the engine and complete the system's check.
Failure to follow this procedure could result in incorrect operation of many BSI related items
Have you tried refitting the original HU?
yes i did put the old hu back in and its still flashes on dash and wnt start can these imob be bypassed
Yes there is, but don't do it for a laugh.
http://www.berlingoforum.co.uk/showthread.php?tid=366
More description:
Quote:i had the same problem yesterday but i have a number pad.... best and quickest way to fix it if u dont want to have to go to citreon and pay for new keys and new immobiliser is to,
get a grinder out, grind off the tamper proof cover over the fuel pump solinoid, open the solinoid up take the plunger bit out, thorw it away, u can cut the 2 wires going to the plunger bit, then put it back together. hey presto it will start, but u have to stall it to stop it. u can get a replacment plunger bit that u need to wire to a ignition and gnd, and then it will be fine but there wont be an active immobiliser in it.
thx mate ile check the fuses and then do that 2nd thing above thanks for your help much appreciated
does the t reg models have centrel locking
well guys all sorted thanks to ANDRE THX DUDE
No worries mate, glad its sorted. Which answer solved it for you, i gave you about 5 lol.
Just click the "Mark as Best Answer" so others can benefit; would be appreciated :thumbsup:
Last Post: BrianS
Today 12:56 PM
» Replies: 22
Pling sound when door open
Last Post: Mark604
Yesterday 07:52 PM
Hello
Last Post: Pricklybuzzz
Yesterday 07:08 PM
Fuel Gauge trouble
Yesterday 10:44 AM
2011 B9 DPF warning light
18-01-2025 11:52 PM
Any advice regarding boot carpets being wet!?
18-01-2025 05:50 PM
» Replies: 21
18-01-2025 10:53 AM
Frequent DPF REGEN's
17-01-2025 08:43 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
17-01-2025 02:29 PM
Power flex anti roll bar bushes
Last Post: NANO_Vigo
17-01-2025 10:54 AM
