Threads: 69
Thanks Received: 22 in 22 posts
Thanks Given: 7
4
Hi all , help needed !!!! i am trying to replace front o/side side light bulb , i have removed both light covers, and cant see where the bulb is ?? is there something else i should be removing ?? or is going to be a" blind " fiddly job ?? thank you all in anticipation
GWYN
nice to be important,more important to be nice
my ride is a berlingo forte 1.9d 2003 model in pukey blue
Threads: 37
Thanks Received: 38 in 37 posts
Thanks Given: 11
No nothing else needs removing, look through the headlight (outside) it will give you an idea where it is.
Threads: 69
Thanks Given: 7
4
23-09-2017, 03:26 PM
(This post was last modified: 23-09-2017, 03:28 PM by my mucker.)
thanks for that !! i can see where it is !! but not from inside !! is it a push and pull ?? or is it a twist and pull ??i just cant get my fingers on it to find out , because i cant see what i am doing. if that makes sense!
ps. its a lingo multispace forte ,03 model by the way !!
Thanks Given: 188
23
From what I remember take the back cover off then feel with your hand and you will get hold of the bulb holder it is round. Turn it and it will come out complete with the bulb. replace the bulb then put it back in the hole and turn it the opposite way to removing it. It is fiddly but once you get it out it will make sense.
Are we there yet?????
• my mucker
Threads: 69
Thanks Given: 7
4
Yes Tomcat all done now !! thanks,it is a very fiddly job,as you said ,i used a small mirror in the end to see where it went!!also found it easier to remove headlight bulb to get its wires out of the way !! once again thanks
