  • 30 Vote(s) - 2.77 Average
alloys for 99 berlingo
not sure if this is the right category for this
but im looking for alloys i can get for my 99 berlingo multi space as on my profile pic
i want to get them as cheap as possible
any advise
thanks clare x
Clare, when you're looking for alloys the first numbers you should check match up are:
PCD-4x108 Offset-15 to 20 Bore-65.1
PCD is how 'spaced' out the bolt holes are that bolt the wheel onto the hub of your Berlingo.
Offset, which can be adjusted with spacers, is pretty much how far in or out the wheel is away from the car.
And the Bore is the size of the center hole of the hub, which the alloy will slide onto.
So im sure you will get plenty of suggestions in the thread, but as a rule of thumb, similar makes of car like the C2, C3, Saxo, Pug 206, and so on also should have the potential to fit.
As for a place, try fleaBay, i've got hold of decent sets of alloys for £50-£100, so no need to break the bank. I'll keep a look out.
[-] The following 2 users say Thank You to Andre for this post:
  • clare baird, ron
Nice set went on Ebay last week for £125 all with good tyres
[-] The following 1 user says Thank You to muply for this post:
  • clare baird
thanks for respones and if gusy can keep an eye out for me im not on ebay that much it be much appreciated
thanks x
these alloys fit on berlingo and are easy to find and very cheap http://www.ebay.co.uk/itm/PEUGEOT-ALLOY-...2316072193 http://www.ebay.co.uk/itm/Peugeot-15-all...1c20b0d45b only thing you will need the right alloy wheel nuts http://www.ebay.co.uk/itm/PEUGEOT-ALLOY-...415cc77d12 , i managed to bag a set for £40 with tyres and wheel nuts.
[-] The following 1 user says Thank You to finny for this post:
  • clare baird
I've got saxo vts alloys on mine, they came with it, lOok smart without being chavvy
The saxo alloys look too small in the arches for me, but there's plenty to be had on ebay for not a lot of money.
Agree they are quite small, if I was buying I may go for something bigger, but mine is a white panel van and they came on it when I bought it
(10-11-2011, 07:52 PM)eliano Wrote:  Agree they are quite small, if I was buying I may go for something bigger, but mine is a white panel van and they came on it when I bought it
Like these?
[Image: 84043006.jpg]
If so, they are quite smart, just maybe a bit small.
No not like them, the 5 curved spoke vts ones
, I can't insert a pic from my iPhone
Warranty on parts
Yesterday 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
02-08-2026 02:22 PM
Berlingo 2026
Last Post: xtimex
29-07-2026 03:34 AM
