Head lights not working
Hi
I have a 2003 berlingo 1.9 dw8, recently changed it to a dturbo engine. But now the headlights wont work at all. Side lights work, main beam only works when you hold the switch in but no dip light. Anyone came across this before
Is it comm2000 so big fat stalks (30-35mm?) with round end or is it the last of the modular ones with a thinner 20ish mm stalk with a square end?
The round stalk. The wipers aren't working either.
Sounds like a com2000 issue, the horn and airbag go through hard wired connections, you may have lost a power supply to the com2000 which Ive had before, or the com2000 has died a death which is more common Wink
What is the com2000 and is there a way to find where the problem is?
It is the part under the steering wheel that the indicators/wipers/radio and possibly cruise control are attached to. It looks like this http://www.ebay.co.uk/itm/CITROEN-PEUGEO...SwbYZXe5p9
But this may not be the exact version in your car.
Rear door filling with water
Yesterday 06:56 PM
MOT Emissions repeated fail
Yesterday 06:53 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
