ive got a 58 plate partner tepee and the blower only works on number 4. ive taken the glove box off but couldnt find the blower:S anyone able to help me with where it is?
Threads: 28
Thanks Given: 78
Hi, it sounds like it the blower resistor pack, its a common fault on Renault's and probably similar on Citroen/Peugeots
Mark
from what ive found on ebay it could be one of 3 types but i dont know where the blower is in the car even to find the resistor
Threads: 12
Thanks Received: 386 in 274 posts
Thanks Given: 16
37
The blower fan is above the accelerator pedal, the resistor pack is either next to it or built into the motor, depending on the type it has.
Threads: 73
Thanks Received: 44 in 33 posts
I had the same problem and my fault was the control panel. the resistor was ok.
