[Engine] no crank,eco active
Hi everyone,
I have a 2008 diesel berlingo, has behaved fine for a year and i have serviced regularly.I now have eco active in the display,
i know all the general blurge about i have left the lights on, radio etc...but i havent. the battery is showing 12.9 volts, sometimes
if i persist with the key occasionally it will crank and start. does anyone know if this can be programmed out, any suggestions to overcome what seems to be a system designed to scrap a lovely tidy well loved van.!! Any help would be really appreciated. chris
You can't disable it you can prolong the timing. eg from 15min to 30min.
You can do that only with lexia diagnostic tool.
Something is left on after you remove key. BSI senses that and turns on "eco mode"
The best way to find out is to remove fuses one by one and measure current drain from battery.
Before that you can do BSI reset. Search on forum for instructions.
best regards,
brajomobil
Eco has nothing to with it not starting, it kicks in and can only be cancelled by starting! Eco mode WILL NOT stop the vehicle starting, you have other issues, I’d suspect a starter or earth fault to the starter
(09-10-2017, 06:36 AM)brajomobil Wrote:  You can't disable it you can prolong the timing. eg from 15min to 30min.
best regards,
brajomobil
Not quite the correct definition of eco mode, the bsi will drop into eco mode whether you have something on or not, it just does it to remove spurious power consumers and stop your battery being drained any further! It switches all ancillary off whether or not the ignition is on, it’s just that when the ignition is on your made aware of it by the bsi/display calling it ‘eco mode’
Today 08:36 AM
» Replies: 15
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
