New van
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
Well finally got the new van on Friday,850 kg,100 PS,but in white ,wanted red but couldn't wait 16 weeks,!!,already slight problem,clutch realse bearing is making a slight noise ,great!!, here we go,lol,only done 350 miles,vans going in tomorrow for them to look at it,,
Threads: 16
Thanks Given: 46
5
20-10-2017, 06:24 PM
(This post was last modified: 20-10-2017, 06:31 PM by Opensauce.)
Shouldn't be a problem. Mine did that when new last March. 100ps Multispace. I told service dept & they said noise should go away after a bit of mileage & after 8k miles it has almost. If I start engine with radio off & door open there is a slight noise that stops when clutch is floored. In normal circumstances it is not really noticable.
Thanks Given: 8
5
20-10-2017, 08:19 PM
(This post was last modified: 20-10-2017, 08:20 PM by Johny555.)
Its in the garage now gear box out,release bearing changed,still noise,gearbox out again,the noise is denfantly inside gear box,I'm waiting for Citroen to get in touch on Monday,may need new gear box,!! Not a good start,,they tried 2 more berlingos their and they didn't make any noise,hasn't helped but the Citroen tec is on holls till Monday ,and aparnetly Citroen will only talk to him,?? So vans been there a week already and still in limbo,but they lent me a hire van,
Threads: 8
Thanks Received: 507 in 455 posts
Thanks Given: 305
37
(20-10-2017, 06:24 PM)Opensauce Wrote: Shouldn't be a problem. Mine did that when new last March. 100ps Multispace. I told service dept & they said noise should go away after a bit of mileage & after 8k miles it has almost. If I start engine with radio off & door open there is a slight noise that stops when clutch is floored. In normal circumstances it is not really noticable.
You noticed it
Threads: 16
Thanks Given: 46
5
21-10-2017, 07:43 AM
(This post was last modified: 21-10-2017, 07:49 AM by Opensauce.)
Yes I noticed it but apart that from everything is ok & noise reduced after 1k miles or so. Over 8k miles now half of that towing a 900kg caravan. If you listen very carefully there is always a different sound clutch in or out. It would depend what you call excessive. Mine is only noticable radio off & door open.
Obviously I can only go by what my dealer service says. Certainly if noise was excessive I would be bending their ears about it. They said other owners have mentioned this as well but Cit say no probs.
Presumably fault with Johnny's van is not release bearing from what he writes as it appears there is a fault in gearbox? Obviously not a good start but good luck to him & new gearbox should sort it.
Threads: 20
Thanks Given: 2,126
18
(11-10-2017, 03:31 PM)Johny555 Wrote: Well finally got the new van on Friday,850 kg,100 PS,but in white ,wanted red but couldn't wait 16 weeks,!!,already slight problem,clutch realse bearing is making a slight noise ,great!!, here we go,lol,only done 350 miles,vans going in tomorrow for them to look at it,,
That's why you have a warranty.With mass production there will be the odd defect.At least they're not trying to fob you off.Think positive.
Strawberry flavoured windows
Thanks Given: 8
5
Had 19 miles on it,had it 2 days before I heard the noise,ringing Citroen up latter to see what's going on,
Threads: 7
Thanks Received: 61 in 55 posts
Thanks Given: 16
Release bearings will always make some noise...
Thanks Given: 8
5
23-10-2017, 05:00 PM
(This post was last modified: 23-10-2017, 05:01 PM by Johny555.)
Never had one make a noise before in 30 years of motoring,! And Citroen rang me theres tsb,bulitin, 5 gear syncro problem,so they have contacted Citroen asking for permission to order new gearbox,they can't order one until Citroen say OK,so vans back together and collecting in the morn,then just have to wait to see what Citroen say,? If they say ok ,van needs go back for new gearbox when ever gearbox arrives
Threads: 20
Thanks Given: 7
15
interesting there is a TSB on the syncro - i've just rolled over 52k in my 65 plate and starting to get a little bit of a crunch on reverse
1.6hdi starting problem
Yesterday 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
