Threads: 5
Thanks Received: 1 in 1 posts
Thanks Given: 3
Well the Halfords specialist does not have much of a clue. I was able to go into Halfords and order the leads. The guy there was most helpful. Now I did find that when using the Control Pro Software box, and other adaptor leads, I was able to use the original audio stalk control with my Pioneer unit. However I was not able to change the display clock settings, as these were changed using the menu buttons on the original head unit. This might be due to the car needing to be set up differently in the Car's software - I am not sure.
I do know that others have used different control boxes and leads and have been able to use the audio stalk to change the clock time. So it is a case of checking before you buy. If the display clock is not a big issue, then you have nothing to worry about.
Threads: 5
Thanks Given: 3
These were taken off my Halfords receipt. I am in Ireland, but the product codes will likely be the same.
285236 ControlPro SWC-Peu/CitQU
650465 AL PC5111 DinFacSOT Ant
The Control pro software box came with a couple of adaptors, which should let you away. The only other thing that I needed was a antenna adaptor as detailed above. With the Control Pro Box, you can reconfigure the audio stalk buttons to do different functions, but I just left them as standard. Also the right hand wiper stalk controls the trip computer functions regardless. The control pro box will only help wire up your audio stalk.
Also you need to be careful, as I struggled getting power to my head unit. You might find that you will have to patch a wire across, inspite of using the adaptors. I hope that it all works out for you.
