Threads: 16
Thanks Received: 1 in 1 posts
Thanks Given: 1
Hi, I recently replaced the throttle cable on my mk2 berlingo van,the new one was bought online, and came in kit form, cut to the same size as the old, and all seemed well(the inner cable is much thinner than the original) but im now finding it has no power whatsoever, could this be a problem related to the injector pump anyone any ideas as to what has gone wrong?
Threads: 65
Thanks Received: 715 in 612 posts
Thanks Given: 226
50
Have you adjusted out the free play in the cable ?
Pump ??? Why was there a power problem before - red herring in my book
I assume it is a 1.9D ?
Serieal Berlingo owner
Threads: 16
Thanks Given: 1
All play adjusted from cable, no issues before fitting
Threads: 7
Thanks Received: 209 in 121 posts
Thanks Given: 16
9
24-10-2017, 12:05 PM
(This post was last modified: 24-10-2017, 01:48 PM by Gravity.)
Just a random thought ... some cheapo cables have an outer sheath that is poorly wound and will compress under load. The cable adjustment seems fine with no slack until a load is put on it, then the outer sheath contracts, taking away some of the inner cable movement.
Worth a check?
Gravity
Threads: 65
Thanks Given: 226
50
With the bonnet up and a helper pressing the accelerator pedal see if you can get full travel of the pump actuator lever. With foot to the floor then see if you can move the lever further by hand.
Threads: 16
Thanks Given: 1
very possible gravity, thanks for that, i bought a cheap one online, fitted and had this problem, so bought one from local parts shop, over twice the cost, only to find it was exactly the same kit! but thanks for the input
Threads: 16
Thanks Given: 1
will give it a go, cheers geoff
Threads: 7
Thanks Given: 16
9
Really pleased to hear that. Great that you're now rolling normally again.
Gravity
