Threads: 2
I cannot open the bonnet of my 2004 Multispace. Release handle moves but does not activate catch. Anybody know how to resolve this. Thanks
Alun Price
Threads: 44
Thanks Received: 11 in 10 posts
Thanks Given: 19
Though I usually can open now I did use to carry a stick to get to the catch. Sods Law is it will be at an inappropriate time, place and weather when you want to get to it; you have to lift the bonnet a bit to assist; or change your hands to those of a chimpanzee.
Threads: 7
Thanks Received: 209 in 121 posts
Thanks Given: 16
9
The release catch has built in slop. It's a poor piece of 'afterthought' engineering.
I remedied this to some extent by carefully bending the metal part that the plastic handle is attached to, so that it was slightly raised and more forward, making it easier to locate. This can only be done a little, otherwise it fouls the bonnet when you shut it.
Of course, to make this adjustment, you first have to open the bonnet ... !
Gravity
Threads: 29
Thanks Received: 375 in 329 posts
Thanks Given: 67
20
If you get an assistant to press down on the front of the bonnet a little it takes pressure off the catch. Lubricate the under bonnet parts when you get it open.
Threads: 11
Thanks Received: 123 in 109 posts
Thanks Given: 16
8
Do you mean the handle in the vehicle or the handle that releases the bonnet once popped? As you have suggestions for both above?
