ABS Module - HELP!
Guys,
This is my first post. I'm desperately needing some help with an ABS module issue on my 2008 1.6HDI (ABS ECU no:- 0 265 800 738).
The module is giving issues and randomly locks up different brakes - a new module (or repair) is required.
Due to the type of board inside the module only two companies in the UK can repair (one of these only deals with garages).
I assumed that I could get a module from a scrappie - how wrong was I!!
Surely with all the Berlingos, Partners and other Citroens like Xsaras on the road who use the same module there's a work around??
I tried a newer module with ECU 0 265 801 739 but when trying to connect with the software couldn't get it to communicate.
Can anyone help me as my van been off the road for 6wks due to this!!
Steve.
Hi Steve,
Have you tried Actronics in Colchester?
If one of the companies happens to be BBA Reman, then avoid them. They made a repeated hash of my abs unit on another car.
Gravity
(07-11-2017, 06:05 AM)snewlanx Wrote:  Guys,
Steve.
Hi Steve,
You can exchange modules as long if 3 last digits are different , first 7 digits must match
In your case: 0 265 800 xxx
You can can try to reflow your abs module in the owen. Google for VGA owen reflow/repair.
You can use your van without ABS . Use your foot as abs  Wink
best regards,
brajomobil
Last Post: mikeh79
Yesterday 07:00 PM
M59 unlocking itself
11-11-2025 09:33 PM
04-11-2025 09:48 PM
04-11-2025 09:15 PM
horn
03-11-2025 08:41 PM
How many miles
03-11-2025 08:12 PM
03-11-2025 08:08 PM
02-11-2025 07:53 PM
Boot liner with 7 seats
31-10-2025 07:57 PM
Last Post: Buki
31-10-2025 07:26 PM
