Threads: 20
Thanks Received: 13 in 13 posts
I need a second hand front suspension strut for my 2004 2.0 hdi berlingo.
Looking on ebay and not many for the 2.0. but plenty for the 1.6 and 1.9. Are they all the same or does it have to be a 2.0 one?
Thanks.
Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 137
33
I think you'll find that they are the same , only difference will be the springs.
I got two new ones last year for 35.00 each (2001 model 1.9) and they were listed as zx,xsara or berlingo .
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 123
Thanks Given: 250
34
My '04 2.0 has very strong springs as I discovered when I needed to change the bearing at the top of the strut. Even the local garage struggled a bit to get it compressed. I expect the struts are the same as Brodfather says but just in case I'd check the part numbers.
Threads: 20
Thanks for the advice.
So the 2.0 has stiffer springs I presume? I tried replacing a spring a couple of years ago and it was a nightmare so ended up taking it to a garage to be compressed.
I've managed to pick up a s/h strut with spring off a 2.0 on ebay for £20.
Cheers
