Newbie !
Hi there, hello and just to say I,m into my third week of Berlingo ownership and feel as though I,m slowly being converted to a "Berlingerer!" Impressed with the amount of space and how easy everything seems to work. I,m running the 2.0 Hdi which seems more than capable (only done 75000mls with two owners since 2004). The most annoying thing I,ve found so far is RATTLES !!, particularly in the rear tailgate area, any advice more than welcome! Wink
Hello and welcome to the forum auspom48. Yes, there can be rattles. I fixed one caused by the plastic cladding on the tailgate. A couple of the white plastic retaining clips had broken off. Still have a few others I haven't located yet. Just turn the music up ;-).
Hi & welcome.I hope you sort your rattles out before you crack.
Hi and welcome - you have a low mileage 2.0hdi have seen them north of 300k and still going strong.
Thanks for the welcome guys. Spent a little time sorting rattles yesterday and fixed the overhead storage area rattles by putting a half turn on all the fixing screws and creating two small wedges and inserting them between the top of the CD holder and the roof. Seems to have done the trick. thanks 3rensho re the plastic clip trick, I was wondering how that panel was held in place, now I can investigate and maybe fix the most annoying rattle! Berlingo came in handy today as I was asked by a relly to move a mini piano! Swallowed it no problem,mind you it made the back suspension work i bit !!
triangle light
Last Post: norm1
Today 12:20 PM
Yesterday 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
