Stereo intermittent fault
Anyone any ideas what might be causing the radio to work intermittently.? Never had a issues with it until a few days ago. It powers up no issues however no sound comes from it and struggles getting a signal. Lock and leave it and it works fine, drive back from work and it has the same issues? Was thinking of upgrading it to a DAB radio soon but curious to get it sorted.
BSI reset still the same, all connections are secure slight corrosion on aerial cleaned up bu same fault
Does it play CD's ok? If so, maybe the aerial connection just inside the roof above the interior light?
Do DAB car radios work ok in the UK these days?
Just put it back together mate and made a gasket out of silicone the nut was loose but unfortunately this hasn't cured it either!!! Yes DAB works well around here in the wife's mini. There are occasional areas where no reception is gained but on the DAB front it's getting better. Looks like it's a new stereo sooner rather than later. Oh, forgot it's a tape not a CD so can't even test it that way ???
On the plus side, a DAB radio will probably need a new aerial. Must confess that I also have no tapes for along while. I had to borrow a tape to test my Volvo stereo a few years ago, once I knew it worked I bought an adaptor so that I could play my MP3 player via the tape deck.
I used to have one as well, in my ford fusion lol !!! I have thought about a newer berlingo as well but lack of funds lol !! So add stereo to cam belt and water pump on things to do list!!!
A new (used) stereo has now arrived. It's an Alpine model with bluetooth DAB etc. I now need to now if anyone can recommend a decent stereo harness so i can keep the steering wheel controls and also a decent dab aerial ? Thanks
Forum activity
Today 01:15 PM
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
steering column bearings
07-05-2025 07:53 PM
