Dropping 1.9d engine one side
Hi
Is it an easy job to drop the 1.9d xud engine one side to gain easy access to the belt and tensioner?  Its a bugger to get into
Which belt ??
Anyway assuming timing belt I find there is sufficient room simply by removing the top engine mountings on the belt side of the engine. Yes it is snug and you may perhaps need to shorten an allen key but certainly doable, raising and lowering the engine on a jack as needed helps a lot.
Going beyond this sounds like a lot of work.
  • Jaques_Schitt
Auxiliary belt
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
