About the change the pads on my 2000 1.8 multispace. I know for a fact (from other car experience) the the nipples will be a PIG to move and bleed through so im going to try and get a couple before I start.
I cannot for the life of me find any info about their sizes though.
Anyone?
Threads: 25
Thanks Received: 47 in 29 posts
Thanks Given: 23
not sure you need to bleed the brakes if you are just changing the pads,
Threads: 9
Thanks Given: 316
15
Just soak the nipples in release oil over night give them a spray in the nipple too you should have no problem bleeding the brakes. Best to replace the fluid every two years anyway.
If you do need nipples i would have thought you could get them from GSF or euro car parts or a citroen dealer for very little.
