[Warning Light] Parking sensor fault
Sent from my iPad using Tapatalk
Lads, have a fault on the parking sensor on my van. Coming up on the dash as a parking assist fault. Any ideas.
Check all the connections and they look good. Notice there is a control unit inside the back passengers arch.
Check the sensors are working, a working sensor gives off a quiet clicking / ticking sound which you can hear if you put your ear close to it.
I know on my car you have to have the engine running for the system to operate, it doesn't work with just the ignition on, if yours is the same you will need a helper to put the car in reverse whilst you listen to the sensors.
Thanks will have a look at this. Here is the fault that’s coming up [Image: 9320cf03db0cffa5b861ab50a68fcef2.jpg]
How about a good old bsi reset see if that sorts it
(27-11-2017, 06:03 PM)Oi69 Wrote:  How about a good old bsi reset see if that sorts it
Do tell me more.
Do tell me more.
its on here somewhere telling you how to do it just search bsi re set switch engine on off leave window open remove battery stand on your head for 30 seconds few things to do or if you have a lexia i think i have seen an option in there to reset it as well
[-] The following 1 user says Thank You to Oi69 for this post:
  • staggc
I had this once in my Partner...it was originated by a faulty reverse switch that sits on top of the gearbox (the actual sensor that indicates to the car BSI that you engaged the reverse gear). The switch was faulty giving an intermitent signal to the bsi, leading to this fault. Replacement costed less than 10 euros and buying a new, big socket tool to remove it and refit it.
It's  impossible to diagnose the fault without some diagnostic gear, diagbox being the obvious 1st choice. My Autel system would also do it.
In 99% of cases the fault will be one of the sensors gone faulty, which switches the whole system off.
Diagnostic gear will identify which one is at fault.
A bsi reset will NOT cure a fault with anything other than a bsi system and its associated can bus systems
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
