2000 Berlingo Stalling & idle issue
Hi All
New to this forum and hoping someone can shed light as no once can so far.
Have 2000 Berlingo 1.4i manual petrol and has a really rough idle then engine cuts out
approx 30 seconds later. Sometimes also does not start then starts ok later.
Drives for a little while then dies randomly. Also "STOP" appears on dash then dies
when give it gas and revs drop really low and dies.
Battery tested and all good. Spark plugs brand new.
Is this a fuel pump or alternator problem?
cheers
If it was fuel pump you'd get issues at high revs.
Maybe the idler valve, or one of the sensors around the throttle housing?
How is the compression on the cylinders?
It's an old engine, and parts wear down...
(I had to replace two cylinder liners and grind the valves and valve seats a bit to get mine fixed up recently. Messy job... )
You need to get a diag done because your list of faults could be various things like ^^^ says idler valve or sensor/s without a diag you will just keep replacing parts until you get lucky.
ASDA AdBlue 10 January 2026
Yesterday 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
Blower fan
04-01-2026 09:58 AM
