Threads: 11
Thanks Received: 2 in 2 posts
Thanks Given: 27
CAN'T GET THE REAR SCREEN WASH TO WORK TRIED STALK IN ALL POSITIONS WITH NO RESULT :justno: HAD A QUICK LOOK AT REAR DOOR AND COULD'NT SEE A WASHER JET IS IT JUST ME :S OR IS THERE A KNACK TO GETTING THIS TO WORK I TAKE IT HAS A REAR WASHER MODE :whistle:.....[/size]
Threads: 41
Thanks Given: 82
6
The MK1 doesn't have one, not sure about MK2 though.
The following 1 user says Thank You to Mike for this post:1 user says Thank You to Mike for this post
• blingo driver
Threads: 63
Thanks Given: 410
If there is a wiper arm/blade then there will be a washer jet somewhere. Are you sure it is not at the end of the wiper arm?
You have to turn the switch for rear wash and wipe??? not position the stalk
Threads: 11
Thanks Given: 27
Andy have turned the wiper stalk and also moved to all positions will mess about with it tommoz see if a can get any joy with it cheers for your input chapZ:lol:
Threads: 63
Thanks Given: 410
(09-11-2011, 10:24 PM)blingo driver Wrote: Andy have turned the wiper stalk and also moved to all positions will mess about with it tommoz see if a can get any joy with it cheers for your input chapZ:lol:
Is it something daft like kinked/blocked pipe or even pipe adrift. They have the stupid knack of running pipes front-to-back through the roof linings etc. Try going somewhere quiet, engine off but ignition on, get front washers operating then listen for pump working then try for rears, believe front/rear wash is off the same pump but with stes of one-way valves. Pump is located under plastic wheel arch protectors near to or attached to reservoir.
Threads: 32
Thanks Given: 18
Rear washer work from a twin outlet pump, when rear wash is required the voltage is reversed so it pumps from the second outlet.
Could be a faulty pump or a blockage in the second outlet, or in the spray nozzle.
Threads: 32
Thanks Given: 13
It should be sited at the foot of the wiper arm.
Threads: 19
Thanks Received: 18 in 11 posts
Thanks Given: 21
10-11-2011, 02:54 PM
(This post was last modified: 10-11-2011, 02:57 PM by jamesf.)
Hi
All 'car' Berlingos have wash/wipe - comes out of two nozzles in the middle of the wiper arm. If yours doesn't have these then something has gone seriously wrong somewhere!
If these aren't blocked (use a pin to clear) then you'll need to make sure the motor is working (there may be one as mentioned above, or two - one for the front, one for the back), which you should be able to hear working (ignition on, turn the control on the column stalk).
Still no joy? Then you'll need to try to trace the route of the pipework through the car.
I have just discovered that the pipework goes through the interior of the car, not in the roof lining but along the floor. I had cause to look in the rear footwell 'secret' cubby hole behind the drivers seat the other day and discovered it was full of water! I took the linings out and found that there is a water pipe running through there, presumably for the rear wash / wipe. There is a connection in there and maybe this has come adrift on your car?
Good luck!
Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
Im not sure where it is on a mk2 but a mk3 is on the 3rd brake light.
I DO MISS MY BERLINGO
