Cheap PP2000 OBD Scanner for Citroen&Peugeot
Hope it is ok to post this
Cheap Scanner
https://www.gearbest.com/other-car-gadge...ml?wid=107
£17.48 with code eubf20-2
Unless I'm reading the blurb wrong, it looks like this will only run on Windows XP.
All my gear has passed XP by long ago, so this may be no good to me.
If I had an XP based laptop, I would need to carry it around in the car if I had a fault show up on a journey.
Correct me if I'm wrong here guys.
Gravity
I assume that is the minimum requirement for the software
where does it say about xp on the add i cant see it i got a little lapbook with xp on and diag tool just keep it ready to use even thoe i have never used it apart from activating cruise controll
It says
Software requires at least Intel Celeron/Pentium III 400 MHz, 128 MB RAM, 50MB free HDD space and USB
1.1 port (USB 2.0 recommended) and Microsoft Windows 98 SR2/2000/XP with the latest service pack installed.
But more to the point is says Discontinued on the first page
Just quoting from the small print on the add, it states:
'1.1 port (USB 2.0 recommended) and Microsoft Windows 98 SR2/2000/XP with the latest service pack installed.'
Whether this means it will not work on later Windows, I don't know. I'm not that tech.
I have an iCarsoft MB2 which I use with great success on my Merc. I may buy the Citroen equivalent, but I'm waiting till I get to know my Berlingo better before deciding.
Gravity
(29-11-2017, 04:23 PM)Gravity Wrote:  Just quoting from the small print on the add, it states:
Gravity
ahh yes see it now but it does say Software requires at least
My iCarsoft MB2 is a Mercedes dedicated scanner, but I have used it on my Berlingo to clear a few generic faults and it has worked well. But obviously it will not delve as deep as the proper tool.
When I get to know the B9 better I will get the right tool for the job.
Gravity
You can get the Lexia kit on ebay for £24.
(30-11-2017, 10:51 AM)ffrenchie Wrote:  You can get the Lexia kit on ebay for £24.
Something fishy there.
The cheap scanner kit originally posted by Jimbo has just the same pictures and write-up as the Lexia kit you link to.
Gravity
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
