Cheap Bluetooth adapter
Hi All,
I recently bought for the sum £5.99 this Bluetooth / FM adapter usb charger.
https://rover.ebay.com/rover/0/0/0?mpre=...3133632407
My rd4 stereo doesn't have Bluetooth function and while I would like to fit a permanent Bluetooth interface into the cd changer socket, but at the moment funds do not allow !
I have to say I'm very impressed with little adapter/ charger, I already was using a usb charging adapter so this was quick swap then I set the radio to 108mhz FM and it picked up the unit then a quick Bluetooth pairing with my phone and the job was done now I've got access to Spotify my 500 albums on my phone tune in radio and of course navigation instructions and can make/receive handless phone calls, not bad for under £6 delivered !
Mark
[-] The following 1 user says Thank You to Satellitemark for this post:
  • 3rensho
That looks pretty slick Mark. May have to look for one in these parts. Thanks for the post.
[-] The following 1 user says Thank You to 3rensho for this post:
  • Satellitemark
I also use a app on my android phone called Bluetooth on call, what this does is turn on the Bluetooth when connected to the usb power lead from the adaptor or (or any other usb power lead) ready to hook up to the adaptor and switches off the Bluetooth when I disconnect the usb lead as I leave the car ( saves battery power and keeps the phone secure)
Thanks for your kind comments !
Mark
  • MarkT
(03-12-2017, 04:01 PM)Satellitemark Wrote:  I also use a app on my android phone called Bluetooth on call, what this does is turn on the Bluetooth when connected to the usb power lead from the adaptor or (or any other usb power lead) ready to hook up to the adaptor and switches off the Bluetooth when I disconnect the usb lead as I leave the car ( saves battery power and keeps the phone secure)
Mark
Thanks for the 'heads-up' on Bluetooth On Call.  I've installed it on my phone and will test it in the car tomorrow.
2013 Berlingo XTR 1.6 HDi 90 (WAV)
2016 Partner Tepee 1.6 Blue HDI S/S (WAV)
2020 VW Caddy Maxi Life 2.0 TDI (WAV)
Mark
You have to go into the apps settings and tell it you want Bluetooth on when on power.
I hope it's as useful to you as it is to me.
Mark
Hi All,
Added bonus is that as my rd4 treats the adapter as a FM station my reversing sensors still work properly which they didn't with with the old parrot system that is installed.
Can't moan for £6 !
I also should mention that android auto is available as a free app download which can manage your music , navigation and phone in a very easy to operate interface.
https://play.google.com/store/apps/detai...n.gearhead
Mark
[Image: 37595aab9c9f5d52c054406ac4217fe9.jpg]
08-10-2026 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
