Fitting a TUNIT chip
I just bought a used TUNIT V-CR and trying to fit it to my 2.0 HDI.
The plug, to the common rail, has an extra bump, which stops me fitting it to the tunit.
Can there be a reason not to lop this off? I's only 1mm x 1mm strip.
I checked the TUNIT site, its the right one for the berlingo 2.0
Think you'll find that the plug is either reversed into the socket or the nib can be shaved off.
I had this glitch a few years ago, and I can't remember which I did - but it worked out fine in the end.
Gravity
(05-12-2017, 04:00 PM)Gravity Wrote:  Think you'll find that the plug is either reversed into the socket or the nib can be shaved off.
Gravity
was that also with a Tunit and 2.0 berlingo?
No, it was another car, but using a Tunit chip. I had a similar problem and phoned them. They told me that some plugs had this nib and some didn't, but I can't remember whether they told me to shave it off or just turn the plug round. Sorry.
Of course, if your plug will obviously only connect one way round because of its shape or pin connections, shaving off the nib is the only way to go.
Gravity
[-] The following 1 user says Thank You to Gravity for this post:
  • richard77
I tried it, but engine light comes on and I guess it's in limp mode, it wont drive over 2000rpm.
I adjusted the dial 3clicks but I can't tell what number its on, there's no marker
So I don't know why but it doesn't work
Car still drives normally without it
(08-12-2017, 10:55 AM)richard77 Wrote:  I tried it, but engine light comes on and I guess it's in limp mode, it wont drive over 2000rpm.
Why not phone Tunit?
They were very helpful to me. There might be a simple answer, and they're the guys who'll know.
Gravity
I have been too busy
I did the chat thing on their website and have been offered a check/software update for £95 with a new harness
Worryingly, they didnt seem to be sure that the Tun072 was the correct one for the Berlingo 2.0 hdi
Berlingo 07 won't engage 2nd gear
Last Post: Kyleonsite
Yesterday 08:28 PM
knocking from rear
Yesterday 08:23 PM
wipers
Yesterday 06:17 PM
Last Post: xavier988
Yesterday 10:23 AM
Yesterday 10:21 AM
footwell fan
Last Post: de62
13-01-2025 10:13 PM
rear washer fires front?
Last Post: Brooky325
13-01-2025 10:00 PM
Remote key fob window function?
13-01-2025 05:58 PM
Halp, me van had died :(
Last Post: ae3
13-01-2025 05:43 PM
Drop in fuel economy
13-01-2025 09:38 AM
