Threads: 68
Thanks Received: 26 in 22 posts
Thanks Given: 22
Does anyone have any information or knowledge of the Dispatch ? I have a 2007 2nd gen and the gearstick is sooo loose 1st and 2nd are difficult, it looks as if the ball joint is worn out.. Or is the gearstick supposed to be very wobbly so you can't tell what gear it's in ?
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
Threads: 9
Thanks Given: 316
15
The dispatch is a big berlingo really - your problem is maybe cable related as im not sure weather the Relay is cable or linkage gear shift.
If its cable try lubricating the cables - takes ages but cheap - replace cables very expensive!
Linkage - replace all linkage you can get parts for.
Threads: 147
Thanks Given: 263
11
We could add a subsection here if the basics of the models are similar enough...
The following 1 user says Thank You to Andre for this post:1 user says Thank You to Andre for this post
• Tomcat3
Threads: 8
Thanks Received: 504 in 452 posts
Thanks Given: 305
35
(06-12-2017, 11:38 PM)ajcommercial Wrote: Does anyone have any information or knowledge of the Dispatch ? ....
Look the vehicle up on the Catcar info site and it will show the gear linkage so you know what you're dealing with!
https://www.catcar.info/citroen/?lang=en
Threads: 67
Thanks Given: 238
50
Ebay is useful for looking at photos and of course prices.
Serieal Berlingo owner
