How to refit exterior door trim
The black plastic door trim on the passenger door got knocked off when the car touched the gatepost in icy conditions. Only one trip clip appears damaged and I can get a new one easy enough. Is refitting just a push on job? Or do I have to slide it sideways as well? Nothing in Haynes Manual!
(14-12-2017, 09:07 PM)paraman Wrote:  The black plastic door trim on the passenger door got knocked off when the car touched the gatepost in icy conditions. Only one trip clip appears damaged and I can get a new one easy enough. Is refitting just a push on job? Or do I have to slide it sideways as well? Nothing in Haynes Manual!
I will answer my own question since I just saw a bloke in a bodyshop! Pull out all old fasteners from the door probably wrecking a few in doing so. Slide 9 new ones onto the plastic door bumper and push it on to the door. Doh! My thinking was 180 degrees out! Now I know why the fasteners are sold by the 10s.
[-] The following 2 users say Thank You to paraman for this post:
  • ffrenchie, Tomcat3
Warm it up indoors before you fit it as well, the clips are probably brittle with the cold.
Had this very same problem when my new Multispace was clobbered by a piece of scrap metal flying from a scrap lorry, on M25 at the time with nowhere to stop to retrieve the panel. Luckily no other damage and no visible damage to door. My motor had covered 203 miles from new so I bought a new one from local dealer for around £54, it came with the clips.
It was a simple job to push the clips into the door then just a smart tap to the panel over the clips to secure it.
I guess it would be impossible to remove this panel without breaking the clips, the few that were remaining in the dorm were just clipped off and the back bits just fell into the bottom of the door.
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
20-04-2026 02:30 PM
Last Post: jw4821
20-04-2026 12:53 PM
Coolant
Last Post: tomhick024
19-04-2026 06:18 PM
