17-12-2017, 12:33 PM
Just had one of these in with an issue, so thought I would share it with you.
Previously didn't know much about them, as they are all quite new so far & maintenance has just been servicing & topping up the ad blue.
This particular van has done about 150K miles as it's a courier van , it's a 65 plate , interestingly it's an EGS gearbox and so far hasn't had a clutch which is interesting / remarkable.
Van came to us following many dealer trips , which have been unsuccessful or very expensive, & I think the owner found us via this site, so thanks for that.
Seemed a straightforward repair, diagbox said "no communication with additive ecu".
This is quite a common fault on these vans, we have fitted several additive tanks in the past & they are quite expensive, around £300 if I remember.
TBH I didn't even realise that the adblue cars still have elloys as well, this makes it a pretty complex system & quite expensive to run in the long term, they seem to use about 1 litre of adblue per thousand miles, so will just go between 12 & 16k on a full tank of adblue.
Anyway we purchased a new additive tank, this come with no fittings at all or fluid £485 +vat. Apparently it's a different tank to the Euro 5 & diagbox , in fact pass through in this case shows it to have a different ecu number than the ordinary.
Any way we filled the tank fitted it to the car & programmed it all in on the Citroen site. Just for future reference, it took over 20 mins to bleed the elloys, we thought that there was a fault with the van, but apparently this is normal.
We even plugged the old tank in , and it was dead, hence proving it was knackered as we suspected. Soon as the new one was plugged in, off it went again. I was concerned it might burn it out, running so long, but eventually it primed up & all faults are gone.
So we have £485 for the tank, £100 to fit it & program, £30 of elloys(it had a bit left in the old tank) all + vat and €35 for 1 week of online PSA charge.
Quite an expensive job to say the least .
I took a few pics of the old tank so you can see what's in it, not much by my reckoning .
Hope I can get the pics to post up.
https://flic.kr/p/21ePDbc
