[Filters & Oil] Gearbox breather , use it for oil filling
Filling via the breather
I know you can on xsara wandering if this can be done on berlingo ,
[Image: e099ef50520207c938e8.jpg]
If there is indeed a Berlingo breather and the access is there then why not ??
Once removed it is after all just a hole in the casting.
That's what I do it makes things a lot easier.
I’d still pull the plug out of the end of the box so you know the level is correct
You can also fill it through the reverse switch hole if you wish as it’s a little larger for shoving the nozzle in Wink
Yesterday 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
