battery light staying on
battery light staying on but alternator still charging battery any ideas
What is the alternator charging at? Could be a diode down in the alternator back feeding to earth? Could be a bit of water in the BSI.
From memory on the early lingos the wire goes direct from alt to clocks and they don’t really have a bsi as such in the early ones, a big lump of fuse box, so I’d say probably a regulator issue or as said one of the diodes has blown although that tends to give a dim light rather than a bright as per pre starting brightness
which year is your Berlingo from?
I believe they got the BSI around 2000?
Check voltage after you've revved the engine up to 3K or so.
sorry i didnt get back sooner but i was busy running up and down the country as my daughter decided to move house just before xmas but the problem with the battery light was that i should have gone to specsavers as it was the rad warning light thanks for the replys
[-] The following 1 user says Thank You to Jimmy Gibson for this post:
  • polar
Last Post: rom4ik
Yesterday 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
