Threads: 12
Hey guys my injector leak off pipes have been disconnection since I got the car so yesterday I replaced all the hoses with new and refitted the feed pipe to the top of the full filter came to it this morning and it wouldn't start and was full of air so disconnected the feed pipe and blanked and fired up and ran fine all day any ideas as I'm stumped as I've replaced all the hoses with new .?
Threads: 41
Thanks Received: 405 in 362 posts
Thanks Given: 134
31
if the leak off pipes were disconnected then there would have been diesel all over the engine ?
If not then it was something else you connected
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 41
Thanks Given: 134
31
if that pipe is not airtight then overnight all the fuel will run back to the tank . The high pressure pump sucks the fuel from the tank through the fuel filter and relies on airtight joints.
Air can leak into the filter through a bad seal round the top of the filter. I've seen the little pipe stub on the lid cracked at the base..
Something is letting air in when that pipe is not blanked off.
