[Warning Light] STOP light on dash
Hi all im new to the forum, i just recently bought a 2004 Belingo van. The problem is that when i Stop sharp or go around a corner fast a light comes on saying STOP on the dash with another warning light and it beeps 3 times. Its not low on oil as i thought as ive checked this but im unsure of what it can be. Does anyone on here have any idea what it can be.
Thanks Dave
Check brake fluid level .....
As Geoff says ^^^ + coolant coolant and oil level
Yep, brake fluid level would be my first thought
Sent from my Redmi 4X using Tapatalk
I had this, previous only told me this happens so I wasn’t too worried when it did. I fitted a centre display from a Picasso with 3 lines which gives more info. When I took a corner a little bit on the spirited side the STOP light came up on the dash & at the same time a message came up on the new centre display “brake fluid low” when I checked the level it was full, I managed to get a little more in, it’s really full now but the stop sign has not returned.
Yep, same thing happened to me. STOP and warning light showing, despite checking the brake fluid and it been on the max fill level at the advice of a citroen garage I filled mine almost to the top and the light has gone out and not come back..... yet. Apparently the sensor on the m59s are ridic sensitive and will come on if it drops below the max level, like if you brake ??
Engine oil level.
Smile
Last Post: Alberts elbow
Yesterday 10:11 PM
Yesterday 09:32 PM
Yesterday 05:46 PM
Yesterday 05:17 PM
Potential Purchase!
Yesterday 03:03 PM
Diagbox 7.57 download
08-03-2026 09:13 PM
Air filter box removal
Last Post: Harrythephot
07-03-2026 11:03 PM
Berlingo undertray
07-03-2026 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 07:07 AM
