Gear stock rattle
Please help. I have a 64 plate 1.6hdi berlingo with 52k on clock. The van has developed a rattle on the gearstick when in 5th gear but only when accelerating as soon as I take foot of pedal it stops. Any help appreciate as it driving me mad.
Hi Kirk and welcome.
Its a really difficult one to diag from a laptop because it could be so many things, start by checking all your engine mountings. The air filters can rattle their heads off on the 1.6hdi's - all the rubber mountings wear. And the 5th gear can come loose in the gearbox. It will also have a DMF but i doubt it is that if its only doing it in 5th.
Good luck mate
  • kirk9704
I have the very same rattle. From what i've read it seems to be coming through the linkages from the gearbox. I 'm going to top up/check my gearbox oil level this weekend to see if it helps. I'd imagine it is a commen problem but I couldn't find a definitive answer. Let me know how you get on.
Paul
Sent from my EVA-L09 using Tapatalk
[-] The following 1 user says Thank You to Paul Dolan for this post:
  • kirk9704
Hello Paul, did you top up or get any further with the issue. Mine is still rattling. I'm lost as to the cause. Hopefully you have fixed yours and know the answer.
Yesterday 12:17 PM
Last Post: wbchevron
Yesterday 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
