Hello!
Morning, just in the process of buying a berlingo and wanted to say hello...
Hi and welcome - what you buying?
Its a 2014 1.6 hdi with full main dealer history 46k on the clock
I'm trying not to obsess about the turbo problems on the 1.6 hdi any warning signs about this that I should be aware of? Or anything else for that matter!?
I've not completed on the deal yet so do have time to back out of any problems
What model and year Berlingo?
Gravity
Welcome along - let us know what you're after and hopefully we can help you.
(04-01-2018, 11:51 AM)Gravity Wrote:  What model and year Berlingo?
Gravity
It's a 2014 vtr 90 bhp
All cars have good points and weaknesses. The Berlingo 1.6hdi is no different.
If you're really worried about the health of your turbo, firstly run the engine and listen with your head near the turbo. Does it make worrying noises? If it sounds fine, there are a couple of quick checks you can do for reassurance.
In this photo you see a general view of the turbo, and it's easily located when you open the bonnet.
[Image: Turbo_1.jpg]
Here's a close up. I have highlighted the turbo oil feed and air feed.
[Image: Turbo_2.jpg]
When the engine is cold, undo the air feed tube - normal screwdriver, and spring it aside with a little pressure - and run your fingers round the inside of the tube. It should feel smooth and your fingers will be oily. If it feels rough, then this indicates a build up of carbon based sludge, and that spells future potential trouble.
Next, remove the banjo bolt highlighted on the oil feed pipe (allen key, and usually very tight). Leave the pipe itself undisturbed, and avoid dislodging the copper washer on the underside of the bolt, if possible. There is a second copper washer on the upper side of the pipe union, easily seen.
The bolt is hollow and should also be oily without any build up of sludge or gunge. If it is dry or clogged, again possible future trouble.
Make sure you don't get any dirt or dust in the tube or oil pipe when you do this.
Hope that helps. They're great motors with long life when properly maintained.
Gravity.
[-] The following 1 user says Thank You to Gravity for this post:
  • Sdao38
I would not worry about the turbo problems as its been blown up out of proportion. Ive seen many 16v and 8v with big miles on them, just make sure its been serviced and that is all they need.
Good luck
(04-01-2018, 03:31 PM)Gravity Wrote:  All cars have good points and weaknesses. The Berlingo 1.6hdi is no different.
Gravity.
Thanks that's a really helpful reply
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
