[Engine] What alternator please
Hi all, first post and could be quite simple for someone.
I have a 53 plate 1.9d berlingo, has power steering but no air con.
what alternator do I use. I can find both 70 and 80 amp available, I don't believe the right one is necessarily on so looking at the old wont help.
any guidance on this will very much be appreciated. Thanks in advance
Note down VIN and give a dealer a bell. They should know.
The alternator that came off mine (2001) 2 weeks ago has a part no Valeo 96428802 80
which I think will be what you need. The 80 shows its for 80 amps
The dealers will give you a price but not all are keen to give you the part no.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(04-01-2018, 05:14 PM)brodfather11 Wrote:  The dealers will give you a price but not all are keen to give you the part no.
I had the same problem when trying to find out the correct anti-freeze. The local dealer parts dept said they can't give part numbers out, but they are printed on quotes... So he suggested I went in and collected a printed quote, which I did.
As far as the actual parts are concerned, I normally look here first if I'm in doubt:
https://www.catcar.info/citroen/?lang=en...MwMw%3D%3D
MOT Emissions repeated fail
Last Post: Marsaday
Today 10:41 AM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
