What Other Seats Will Fit a 2006 Berlingo?
Hi guys, just bagged my self a 56 reg 1.9D berlingo for £200  Big Grin
The van has an impressive 420k on the clock, but its had 1 owner, been on the motorway most of its life and has been regularly maintained. I'm wanting to make some slight alterations to the van, the main one is having rear seats. Fitting rear seats wont be much of an issue but as the van does not have a side loading door, I thought about replacing the front seats for folding ones, the ones you would normally have in a 3 door car to allow passengers to get into the back of the car.
Does anyone know if Pug 207, 307 3 door seats would fit without any welding and fabrication? or ones from a 3 door Citroen?
Many Thanks
You may run into big problems at MOT time as the seats will have to be properly mounted and you will have to have seat belts that are in proper anchor points. There are various threads on here about changing seats and as I recall no seats will swap straight in you will have to modify the seat runners.
Rear seats will almost certainly be an issue with insurance & MOT, but up to you. Front tip seats on the passenger side are often fitted to M59 Berlingo vans, I have one in my multispace. Problem is that the lower frame does not move so no adjustment or recline and there's a large lump of metal to step past.
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
