  • 9 Vote(s) - 3.22 Average
Instrument Cluster faults
The instrument cluster on my 2001 Multispace 1.4 has taken to working intermittently. None of the gauges or warning lights work, nor does the cluster light up if the headlights are switched on. Usually the display flickers for the first couple of miles, then everything boots up- though often the fuel gauge isn't reading accurately. Sometimes there are spurious warning lights which fail to go out when the ignition is switched off. This drains the battery. It gives the impression that maybe a multi-connector may be loose or contaminated with water somewhere. Any ideas anyone?
Have u checked for water ingress in or around the fusebox, right side under steering wheel, failing that moisture or
Corrosion in the instrument cluster plug itself, my van has had loads of leaks in this area, changed windscreen , and unclogged drains that run into wheel arches, solved my problems , for now !!!
Last Post: TGD
Yesterday 09:50 PM
Yesterday 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
