[Engine] Millers and dpf
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
Millers and dpf,would it be OK to start using millers,any affects on the dpf,?used it in my old berlingo none dpf,and the van ran a lot better,just wondering if it will be OK to run millers on my new van,cheers
Threads: 20
Thanks Given: 2,126
18
(01-02-2018, 12:33 PM)Johny555 Wrote: Millers and dpf,would it be OK to start using millers,any affects on the dpf,?used it in my old berlingo none dpf,and the van ran a lot better,just wondering if it will be OK to run millers on my new van,cheers I've used it for 2 years & 11,000 miles in my Blue HDi 100 & nothing has blown up/fallen off.To clarify,from new.
Strawberry flavoured windows
Threads: 9
Thanks Received: 441 in 402 posts
Thanks Given: 316
15
Ive know a good dose of millers to clean out a dpf so its more than fine to use it johny
Thanks Given: 8
5
(01-02-2018, 09:04 PM)doofer Wrote: It depends on the ash content. It doesn't contain any ash, ash content is a measure of how much of it is left after it's been burnt. For the same reason, engines that have a DPF use low ash oil, because a small amount of oil gets burnt so anything left after burning it ends up in the DPF. There is no way out for ash particles in the DPF, so they build up and eventually block it - after which you need to buy a new one or have it cleaned at lots of expense. The soot from diesel is almost entirely carbon, i.e. unburnt fuel, so when it does its regeneration the soot gets burnt and almost all of the particles blocking it turn into gases that can exit through the filter. But anything that isn't capable of turning into gas gets left in and will eventually block it.
It would be perfectly possible to be gradually adding to the ash blockage in the DPF for thousands of miles and have no apparent problem at present - you would only be aware of it when the DPF needs replacing as it's full and a regeneration isn't clearing it.
So the answer isn't a Yes or a No, but to check whether it's intended for use with a DPF and/or whether it's rated as Low Ash. There isn't a way of checking this other than checking labels, specs or asking the manufacturer. It's possible that it's absolutely fine, or you may need to pay extra for a special version of it. Low ash oil is always quite a lot more expensive, so the same may apply here. Cheers for that,I know millers was OK for my old Berlngo no dpf,,wasn't sure about the new Berlingo with dpf,I thought will it clog the dpf sooner, or will it be OK,?,
Thanks Given: 8
5
03-02-2018, 07:06 PM
(This post was last modified: 03-02-2018, 07:09 PM by Johny555.)
(03-02-2018, 06:57 PM)doofer Wrote: Errr... ask Millers?
Err... u got Fone number,? So all the problems the members have why ask on the forum,why don't they ask Citroen???
Threads: 7
Thanks Received: 206 in 121 posts
Thanks Given: 16
8
(03-02-2018, 07:06 PM)Johny555 Wrote: (03-02-2018, 06:57 PM)doofer Wrote: Errr... ask Millers?
Possibly because fellow owners can give you their personal experiences. Very valuable real life info.
But the only 'official' answer has to come from the manufacturer - in this case either Millers or Citroen. Hence Doofer's comment. Makes sense to me.
Gravity.
The following 2 users say Thank You to Gravity for this post:2 users say Thank You to Gravity for this post
• doofer, ron
Thanks Given: 8
5
(03-02-2018, 09:11 PM)Gravity Wrote: (03-02-2018, 07:06 PM)Johny555 Wrote: (03-02-2018, 06:57 PM)doofer Wrote: Errr... ask Millers?
Gravity.,that's why I was asking on the forum to see if any one had personal experience on millers with a dpf
Threads: 9
Thanks Given: 316
15
Threads: 9
Thanks Given: 316
15
like i said i used it to help clean out DPF - now im done
• ron
Thanks Given: 8
5
05-02-2018, 09:07 AM
(This post was last modified: 05-02-2018, 09:08 AM by Johny555.)
Thanks for replays,I've emailed millers waitng for a reply,just don't want to damage dpf,
Adblue warnings
Last Post: Zion
Today 06:43 PM
» Replies: 24
Berlingo/partner 2019 Gearbox real or fake?
Last Post: Zion
Today 06:10 PM
Electric probs - where to start
Last Post: Zion
Today 06:08 PM
Dash cam with reversing for Berlingo 2019 van
Last Post: RichCowell
Today 01:18 PM
» Replies: 24
Berlingo DPF problems
Last Post: Merlin100
Today 12:25 PM
Stuck glow plug tip - I've tried it all - It won...
Yesterday 10:45 PM
front hubs
Last Post: mopedracer
Yesterday 08:55 PM
Hello to all
Last Post: PapaHub
Yesterday 07:01 PM
Mk II 2018 Anniversary Door Sill Clips?
Last Post: Zion
Yesterday 06:28 PM
Heater control lights.
Last Post: Gadgetman
Yesterday 10:51 AM
