[Engine] Vibration
Hi
I have A 2009 had it about a month now had to have a new clutch fitted due to major judder although now I seem to get vibration through the vehicle seems to be getting worse now it’s a bit like your in wrong gear also some vibration from panels in rear when setting off
Any ideas guys
Difficult to give you an accurate idea from what you say, but it could be that the centre driveshafts have been damaged during the clutch replacement. It's easy to loose a swivel ball off the inner triad if the shaft is not removed reasonably carefully..
Engine /gearbox mount,?
It could be anything from engine/gearbox mounts to binding brakes. You need someone to sit in and listen with you.
Thanks guys will get them checked
(03-02-2018, 10:12 AM)wilky Wrote:  Thanks guys will get them checked
Still not sorted this any ideas from video attached engine looks to move a lot but not sure if this is normal
I can't see a video, did it upload ok ?
Mark
(16-02-2018, 04:27 PM)Satellitemark Wrote:  I can't see a video, did it upload ok ?
Mark
no was rejected to large I suspect 59mb
Mark
<a href=http://www.filedropper.com/img6673><img src=http://www.filedropper.com/download_button.png width=127 height=145 border=0/></a><br /><div style=font-size:9px;font-family:Arial, Helvetica, sans-serif;width:127px;font-color:#44a854;> <a href=http://www.filedropper.com >online backup storage</a></div>
Mark
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
