new van question, blue hdi 1.6 100ps
Threads: 5
Thanks Given: 8
hi everyone,
i am looking for advice please. i am seriously considering buying a new berlingo enterprise 100ps blue hdi 1.6, the spec looks good, air con, e/w/ etc. i really like the look of the van.
i know very little about this vans reliability etc, could you help me please. are there any common faults? would you buy this van? service intervals ?
oh, and the cheapest place i have seen it is pure vans online, £9895 plus vat. is there anywhere cheaper.
many thanks in advance.
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
03-02-2018, 10:23 AM
(This post was last modified: 03-02-2018, 10:26 AM by Johny555.)
Yeah listen for gear box noise, mine covered 19 miles !! Had to have new gear box!! It sounds like relese bearing noise,but I was told its 5 gear syncro,! Put clutch down noise goes away,lift clutch up noise comes back,its not very loud so listen for it,I paid £9450 plus vat,17,plate 100 PS,850 kg,at evens halshaw,
The following 1 user says Thank You to Johny555 for this post:1 user says Thank You to Johny555 for this post
• al673
Threads: 5
Thanks Given: 8
(03-02-2018, 10:23 AM)Johny555 Wrote: Yeah listen for gear box noise, mine covered 19 miles !! Had to have new gear box!! It sounds like relese bearing noise,but I was told its 5 gear syncro,! Put clutch down noise goes away,lift clutch up noise comes back,its not very loud so listen for it,I paid £9450 plus vat,17,plate 100 PS,850 kg,at evens halshaw,
Which Evans halshaw please?
Only 19 miles then trouble, that concerns me slightly. Has it been ok since please.
Is this common.
I drive a vw caddy now, it hasn’t needed a thing doing to it. Put the prices are too high.
Hence why I’m looking at berlingos.
Cheers
Threads: 9
Thanks Given: 316
15
No common faults really you always get the odd one with problems no matter what badge you select. Some of the guys on here have 400k miles + with no problems.
I looked at VW and i thought the Berlingo was better and a hell of a lot cheaper - ive had mine 10 years now.
The following 2 users say Thank You to polar for this post:2 users say Thank You to polar for this post
• al673, ron
Thanks Given: 8
5
(03-02-2018, 04:13 PM)al673 Wrote: (03-02-2018, 10:23 AM)Johny555 Wrote: Yeah listen for gear box noise, mine covered 19 miles !! Had to have new gear box!! It sounds like relese bearing noise,but I was told its 5 gear syncro,! Put clutch down noise goes away,lift clutch up noise comes back,its not very loud so listen for it,I paid £9450 plus vat,17,plate 100 PS,850 kg,at evens halshaw,
Is this common.
Cheers Evans halshaw ,hull,,yeah you can get faults with any new car,my gearbox replaced on warranty but its put me off the van to be honest,new gear box feels notchy changing gears when cold,!
• al673
Threads: 16
Thanks Given: 46
5
Most Berlingos are ok. I had my last one for 8yr/80k miles with few probs. Nothing major. Serviced once a yr at Cit garage. It’s probably as good a van as any. New model out this yr apparantly so should be good deals on current model. Current model uses Adblue. 17litre tank so pour in a 10litre container about every now & then.
The following 1 user says Thank You to Opensauce for this post:1 user says Thank You to Opensauce for this post
• al673
Threads: 5
Thanks Given: 8
Well I test drove the 100ps enterprise van today, it was a nice drive.
I’m just waiting for there latest offers to be released.
He said they were £9700 last month but £11000 this month
Threads: 0
Thanks Received: 1 in 1 posts
Just purchased 2008 berlingo van. Clutch is heavy and seems to have sideways movement when used. Any ideas,?
The following 1 user says Thank You to Wigsy7 for this post:1 user says Thank You to Wigsy7 for this post
• al673
Yesterday 08:03 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
16-09-2026 09:50 AM
» Replies: 16
removing front strut
16-09-2026 02:07 AM
Strut Top Mounts
15-09-2026 07:58 PM
