Folding Wing Mirrors
I have acquired a 62 mpv  1.6 E-HDi XTR
Can anyone tell me if the electrically folding wing mirrors are standard.
The handbook suggests they are. The description for opening and closing  them with the mirror adjustment switch is unclear and I am unsure whether the switch is not working or whether they are in fact an optional feature.
Ta. Huh
I don't think every XTR has auto-folding mirrors.
Mine is an early B9 XTR, and although the mirror adjustment switch has the movement needed for the mirrors to autofold, they do not (ie. ignition on, mirror switch in central position, push switch downwards).
Does yours have heated mirrors? They work when you turn on the heated rear screen.
Gravity
[-] The following 1 user says Thank You to Gravity for this post:
  • macdad1968
The switch that selects which mirror you can adjust pulls towards you to fold them in, usually has a little white arrow on it. Tend to be quite rare I think .
  • macdad1968
(06-02-2018, 04:46 PM)Gravity Wrote:  I don't think every XTR has auto-folding mirrors.
Gravity
Thanks. Yes the mirrors are heated and work in conjunction with heated rear screen.
(08-02-2018, 11:34 AM)doofer Wrote:  I've got folding mirrors and it doesn't push.  You just rotate it to a certain point where it clicks and they fold.
I think from memory, left-adjust is 10 o'clock, right-adjust is 2 o'clock, fold in is 6 o'clock.  I used it just the other week when a truck was squeezing past.
Mine also folds them when I lock it and unfolds when I unlock.  This is an option somewhere in the dashboard options list.
Nope mine not equipped with folding mirrors. Would have been so much easier if the handbook had indicated they were optional and more clear about the switch operation.
Thanks for clearing that up
Hi there mine fold on the switch but can't find the auto fold function anywhere in the menus,I have a 2014 van.
Terry..
Sent from my SM-G955F using Tapatalk
(31-03-2018, 09:08 AM)doofer Wrote:  It should be there, hopefully. You need to have the engine stopped and ignition switch on at the first click to get all the menu options, as it doesn't allow you to change much while it's running.
Top man I'll definitely try that my friend..
Nope still can't find it mus'nt have it!!
(31-03-2018, 02:22 PM)doofer Wrote:  Perhaps some don't have it. I've definitely read of a delivery driver here disabling it, as he was worried it would wear out with the number of times he locks/unlocks it.
Mine's a 2014 Multispace, pre-facelift without a touchscreen. Let us know what yours is, if the same I'll note down the route to the option in the menus. I find it hard to believe that they'd ration a feature that costs £0.00 to implement - the motors are already there, and the thing knows whether it's locked or not, so you'd hope they wouldn't be so mean about it.
Thanks Doofer mine hasn't touchscreen either mate.
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
