04-02-2018, 06:13 PM
Well it was all going so well!
The first three injectors practically flew out of their holes, with their copper seals attached, and it's easy to see why. All three were absolutely soaked in oil along their whole length. OK it's messy but there was hardly any carbon to clean off, apart from a tiny amount where the copper seal sits. A good clean for all three, new seals fitted, so far so good.
Then it came to number 4. Wedged solid in the head, but nothing that nearly 3 hours of gentle persuasion and a whole can of WD40 couldn't fix. The injector was covered in carbon, there was a small quantity in the mounting hole, and the copper seal had not come out.
I managed to clean the bore and then made up a wire hook to try and retrieve the copper seal. First go with the hook, seal never came out, hook straightened itself. I reshaped the hook forgetting all about metal fatigue. Second go with the hook, copper seal never came out, hooky bit broken off from end of wire! Doh! We're talking a piece of 2mm wire about 4 - 5 mm long.
I attached a piece of garden hose to the vacuum cleaner and stuck it down the injector hole with the vac on full power in an attempt to retrieve the piece of wire, but I am 99.9% sure it's still sitting on top of the piston.
It would now appear that my options are ....
1) Take the head off and remove the wire hook.
2) Start it up in the hope that it will be sucked out. Yes it will wreck the turbocharger blades, but it'll be out and fitting a new CHRA is a damn sight less work than taking the head off.
3) Have another go with the vacuum cleaner and hope it gets sucked out.
Any advice would be much appreciated.
