Threads: 12
Hey guys my berlino multispace has developed a problem with the Interior lights they dont go off if in the door position I've taken both switches out the a pilla but neither had wires attached and if I switch my rear wiper on the light go off until its finished its cycle then they come back on I've checked the wires in the boot and all seems ok any ideas would be great thanks
Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 139
33
The interior lights come on when the door is opened , the wire that should be on, the switches earth the lamps so they come on . When the door is shut the switch earth is broken so they go off.
If the wire is earthing in the pillar then the lights will/should come on all the time.
The wires between the doors and the body can break after time because the bending they get with the doors being opened and shut, see if the wires are OK especially in the rear door.
Bad connections and wires touching each other or broken can cause weird things to happen
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 34
Thanks Received: 21 in 20 posts
Thanks Given: 23
(09-02-2018, 03:09 PM)Lucas87 Wrote: if I switch my rear wiper on the lights go off until its finished its cycle then they come back on
I'm sorry I can't help, but that is a bit weird, and I ain't new to vehicle electrics (well, a bit new to French electrics).
Hope you find the cause, and do let us know what it was !!
