  • 1 Vote(s) - 5 Average
Dashboard indicator light
On my 2010 XTR HDI 90 when I indicate right, the green arrow, on the display doesn't light up.
When I indicate left, the left arrow works and all external indicator lights working fine, any idea's ?
I would guess that the bulb for the right green arrow is blown.
That's where I would start.
Sadly I don’t think they are Individual bulbs, so you have to replace the entire clocks to solve this fault from memory, word of warning, get clocks... if second hand... with less mileage than yours otherwise the clocks will write to the BSI as soon as you put the ignition on, but if the clocks are lower the bsi will write its mileage to it and all will be good in the world Smile
I did wonder if they would be bulbs, I know on a set of Renault clocks I had they were surface mount LED's.
If the Berlingo clocks are the same it may just be a cracked solder joint, depending on your tinkering skills it may be possible to repair the problem.
Got in the car this morning and light working again,hopefully just a one off problem, that's put itself right .
Didn't fancy trying to sort it out.
Many thanks for all the advise !
Hope it keeps working.
I have a similar problem with my 2002 Citroen berlingo but my lights come on when I put my indicators on but have no idea what is causing the problem.
M59 1.4 Petrol question
Yesterday 10:48 PM
Yesterday 09:29 PM
» Replies: 27
Last Post: MariusTeamPP
Yesterday 07:01 PM
Yesterday 09:08 AM
Insurance Shocker !!!
Yesterday 09:04 AM
13-03-2025 08:09 PM
How rare is my berlingo
Last Post: Gadgetman
13-03-2025 02:30 PM
Official Citroen internal child monitoring mirro...
13-03-2025 10:31 AM
Anti corrosion spray
12-03-2025 02:35 PM
Rubber pipe in engine bay
12-03-2025 10:16 AM
