Threads: 5
Thanks Received: 3 in 2 posts
Thanks Given: 1
1.6 HDi van.
Occasionally when I brake, it feels as if the servo isn't there, yet if I let off and brake again immediately all is good. So, a few questions;
i) Is this a sign of the servo failing?
ii) do these vehicles have a remote vac tank like the bigger diesels, or is the servo it's own reservoir?
Any help would be greatly appreciated, BH (Pat)
Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 139
33
17-02-2018, 07:29 AM
(This post was last modified: 17-02-2018, 07:33 AM by brodfather11.)
Do you mean when the brake pedal is pressed it feels hard but nothing happens or the pedal goes to the floor as if no fluid.
The servo are quite dependable , don't normally fail . They don't need big air tanks , the servo is all the berlingos need.
The vacuum pump or pipes will give more trouble than the actual servo.
There is a check valve on the vacuum pump which can be tested by removing and seeing if air can pass both ways ,if so its faulty ,its meant to be a one-way only.
To test the servo, pump the brake until the servo is empty (or full of air) then with foot on brake start the engine, the pedal will start to go down as the air is sucked out of the servo. The pedal should then be able to pump up and get harder.
The other culprit could be the brake master cylinder, seals not just quite right .
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 5
Thanks Given: 1
Sorry, I should have been a little clearer.
when this happens ( twice today) it's just hard, and takes considerably more force to stop, just like an older non-assisted braking system. Can lead to a few brown trouser moments if you're not expecting it
Threads: 43
Thanks Given: 139
33
17-03-2018, 06:42 AM
(This post was last modified: 17-03-2018, 06:43 AM by brodfather11.)
(17-02-2018, 09:27 PM)bhcalcutta2 Wrote: Sorry, I should have been a little clearer.
Sorry I missed your reply. Probably too late now but I'd be looking at the vacuum pump and pipes but with it intermittent it is hard to pin down. I'd suspect the valve in the pump sticking now and again.
Hope you get the skid marks on the road soon.
