[Steering & Suspension] squeaky steering
My 1.4 M59 Berlingo multispace is puzzling me.There is a squeaky racket when I turn the steering wheel.I lubricated the rubber thingy which the steering column passes through at the bottom but no difference.
So,genius that I am, I removed the column shrouds and lubricated the plastic ribbed ring(something to do with collapsible column).Again,it made no difference.
This is definitely a plastic to plastic or rubber to rubber squeaky noise caused by the rotation of the steering wheel.
Any ideas welcome?
What about the universal joint at the bottom of the steering column , it sticks and needs a squirt of wd40 type stuff now and again. It sits just through the bottom cover
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
  • byron1992
(17-02-2018, 09:34 AM)brodfather11 Wrote:  What about the universal joint at the bottom of the steering column , it sticks and needs a squirt of wd40 type stuff now and again. It sits just through the bottom cover
thanks brodfather,I think it is fixed Shy
Yesterday 08:03 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
16-09-2026 09:50 AM
» Replies: 16
removing front strut
16-09-2026 02:07 AM
Strut Top Mounts
15-09-2026 07:58 PM
