Thanks Given: 1
Hello,
I have a 2005 Berlingo HDi and the horn does not work.I recently bought the van second hand and the previous owners were electricians!
They have done a lot of additional wiring and rewiring.
Anyhow they have done some rewiring with the horn for some reason, There is no power to the horn and a wire is hanging loose,
I need the wiring diagram for the horn so I can figure it out.
Can anyone assist please?
Regards
Barry
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
my scanner is not working at the moment so I'll try to describe it.
From Haynes manual
Battery to engine fuse box (fuse 8) to passenger fuse box (fuse 17) to steering wheel switches(horn button) to horn to earth.
The wire colours don't mean a lot as they are not consistent. The numbers on the wires are and on the components are.
From C1 at the engine fuse box (wire BMF8, 46Nr) to C1 at the passenger fuse box.(may be green 1Gr) From C17 (fuse 17 @15amp) (wire B17, 34Nr) to 3A at steering wheel switch . From 1A ( wire 250, 5Ba) on switch to Horn then to earth.
With a multimeter you should be able to trace back from horn to switch easily.
There have been a lot of posts about the earthing of the steering column to get the horn to work which may suggest that the horn works by earthing it. Your problems are more likely to be between the switch and the horn.
if the loose wire is an earth then maybe its just fallen off.
There are lots of variations of the wiring on the different models so all this may be not be right for your model.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 43
Thanks Given: 137
33
Wait and I will check out the wiring behind my horn (06 model) this afternoon, just to make sure.
Threads: 43
Thanks Given: 137
33
(20-02-2018, 12:06 PM)brodfather11 Wrote: Wait and I will check out the wiring behind my horn (06 model) this afternoon, just to make sure.
When the air bag is out , at the top of the steering wheel is a plug coming through with three wires from it. The r/hand wire goes to the L/H horn button terminal. the left hand one goes to the air bag . the middle goes to a switch??? mounted at the side of the wheel and from that comes a black wire to earth and a red wire to the R/H horn terminal.
