INTERIOR LIGHT AND LED IN DOOR LOCK BUTTON PROBLEM
Hi,
We have a fleet of Berlingo First vans. one by one they are failing with the following problems.
1) The interior lights stopped coming on and going off when the vehicle is unlocked/locked using the remote control key.
The lights do work when they manually switched on at the lamp.
2) The red LED indicator in the "door lock" button on the centre console does not come on when the button is pressed or the self locking option is activated and the vans are driven.
3) The same red LED has stopped flashing when the vans are locked using the remote control key.
Anybody had the same problem?
Cheers
Thats a very odd one but it does sound BSI related, have you changed the batteries or disconnected them for any reason?
Do a search for BSI reset and follow the procedure, its very easy and your first thing to do
(20-02-2018, 11:25 AM)polar Wrote:  Thats a very odd one but it does sound BSI related, have you changed the batteries or disconnected them for any reason?
Hi,
Yeah have carried out the reset a couple of times to to avail.  I's strange that more than one of them has developed this fault. Am wondering if it is a fuse problem or if it something more serious
Could it be a broken wire in the loom between the door and body ?
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(21-02-2018, 08:34 AM)brodfather11 Wrote:  Could it be a broken wire in the loom between the door and body ?
Could be but got 3 out of 4 vans at this branch with same problem
Yesterday 03:36 PM
Last Post: JPCoetzee
Yesterday 10:34 AM
13-03-2026 09:14 PM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
