Emergency Braking - Engine Timing Belt Issue
Thumbs Down
Hi
I had to brake hard to avoid a collision and immediately my 2013 Multispace xtr ground to a halt. I assumed that some sort of fuel cut off switch had engaged but no such luck! The local Citroen dealer found timing jumped and out by three teeth and timing pinion broken??? The Timing Belt, Pinion and Motor kit were replaced ( cost £728 - £450 of which was Labour costs!!) Has anyone else had this problem?
As I avoided a collision the Insurance company are not interested.......I may have been better off to have been slower on the brakes and collided with the buffoon who failed to look!
All suggestions?thoughts how I may convince the Insurance Company otherwise ? Angry
Thanks for reading this,
Paul
I guess caused by engine being stalled from high speed? Just bad luck. The good news would be that your belt change interval starts again from now.
Last Post: wbchevron
Today 07:34 AM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
