2016 berlingo 1.6 hdi oil change time
Hi all I’m looking to change my oil and filter on my 2016 berlingo 1.6 hdi it’s not on add blue either. What’s the best oil to run in it? and would any of you clever lot know the Citroen part number for the oil filter and sump plug washer.
Hi
Welcome to the forum,
The only two oils that I'm aware of that have PSA B 71 2290 approval are,
Total Quartz Ineo ECS 5W30 and
Fuchs Titan GT1 Pro C2 5w30
Citroen use the Total oil at their garages.
As far as the oil filter is concerned it's safest to check against your vin number to make sure you get the right one.
If your open to using a OE replacement filter the brand's
Mann and Mahle filters are among the most trusted.
You can get ideas on prices of OE filters by entering your reg number at,
https://www.eurocarparts.com/
Mark
[-] The following 2 users say Thank You to Satellitemark for this post:
  • polar, ron
What mark says ^^^^
My local Citroen dealer uses Castrol Magnatec 5W-30 C2 Fully Synthetic which is also PSA B71 2290.
[-] The following 1 user says Thank You to jamesg for this post:
  • Satellitemark
Thanks Jamesg,
I wasn't aware the Castrol oil was approved, I'll keep it in mind for future use.
According to Opie oils Mobil 1 ESP 5W 30 is also approved
Mark
There are a lot of oils approved - as long as they meet the spec just take your pick.
try here Total is well cheap https://www.nielsencdg.co.uk/
  • ron
(21-02-2018, 06:52 PM)polar Wrote:  There are a lot of oils approved - as long as they meet the spec just take your pick.
That's where I get my oils & Millers.
When looking at oils I found plenty of weasel words, phrases such as,
Suggested application
Suitable for
Meets xxxxxxxxx standard etc
It doesn't mean these are not good oils, far from it but it does mean that some manufacturers / distributors / sellers are trying to pass them off as if they had passed the manufacturers approval procedure.
This sort of deceitful practice makes me actively avoid the seller and their product.
I don't mind buying oil without approval if I have faith in it, but I don't want to be mugged into buying it !
Mark
(21-02-2018, 07:44 PM)Satellitemark Wrote:  When looking at oils I found plenty of weasel words, phrases such as,
Suitable for
Mark
Maybe the manufacturers of the the oils that are using the "weasel words" just aren't prepared to pay the vehicle manufacturer the fees they want to grant approval !
Many oil manufactures who's oil meets or exceeds the specifications don't bother seeking approval because of the costs involved.
Suitable for
Mark
That's absolutely fine, as long as they make it crystal clear, but when they list under approvals they list the PSA number with meets or exceeds or suggested for etc this can be misleading.
If they don't want to pay for test ok but then don't use the approval number in the information about the oil, they could just as easily put recommended for Citroen Peugeot diesels but they don't because they want to confuse both the issue and Google, if you do a Google search for PSA xxxxxxxxx you will get oils listed that have both been approved and some that are not because Google sees the PSA number in reference to that oil.
Mark
Emissions fault.
Yesterday 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
steering column bearings
07-05-2025 07:53 PM
Gen 1 cream interior cleaning
07-05-2025 06:28 AM
