22-02-2018, 01:50 PM
Hello all.
I'm new to the forum and have been trying to rectify this problem on my 2004 2.0Hdi enterprise van.
It initially started about a year or 18 months ago and symptoms were that the headlights would come on as soon as I turned on the ignition but the indicators wouldn't work unless the light switch on the stalk was in the on position.
I did some research and the problem seemed to suggest that there might be water damage in the BSI unit. As I knew the floor on the driver side was wet when I bought the van I was convinced it was due to water ingress. I later discovered there was a leak on the radio antenna which I sealed.
I removed the fuse box and BSI unit to inspect it and expected to find all kinds of corrosion and staining but there was nothing. I decided to give it a spray of WD40 and put it back together because I'd not seen any evidence that there was any water damage. I thought once it dried out properly and the penetrating oil did it's job any remaining dampness would disappear. It seems to work and I had about a year or so of reliable use although every now and again, if I'd not used the van for a few days it would show the same fault. A good run with the heater full on usually did the trick and I ignored the problem.
Recently however the problem has come back following another leak in the same place which is now covered with sikkaflex and completely sealed. This time though it's not clearing and one day it's fine the next its back the same. I've had it on a fault code reader which didn't show anything and I checked the pink and white wires and all connections etc again for corrosion but didn't find anything wrong. I've now got the fuse box/BSI unit apart again to see if drying it out on a radiator overnight might do the trick but I'm not hopeful of success.
I read somewhere online that it was possible to replace the fuse box side of the BSI by purchasing a used unit and unsoldering the 16 pin connecting blocks between the 2 boards and fitting the presumably working board from the replacement unit. It's not possible to replace the complete fuse box as the BSI side of it has a unique code to the vehicle but this would be a relatively cheap alternative to going down the reconditioned route and having to get all new coding etc done. The trouble is I can't seem to find the article I saw and wondered if anyone on here could point me in the right direction or indeed advise me on how exactly to go about doing the swap.
The van is only worth about £500 but it seems a shame to have to scrap it for the sake of a bit of solder.
Thanks in advance.
Ian
Thanks in advance.
Ian
