26-02-2018, 08:54 PM
Evening,
I have a 2014 Berlingo enterprise with a 1.6HDI engine, the engine code is dn. The engine went pop so i sourced another one with the same engine code.
Got a garage to fit it, they got the engine fitted and running. Its okay on idle but when you push the accelerator it doesn't rev. It comes up with a cam position sensor error. The garage can clear the code but it returns every time they try it.
They swapped the sensor from the old engine but same issue.
They have got a wiring diagram from auto data for my van but apparently it shows a five wire connection to the sensor and not the three wire that my van has. They got an auto spark in and he seems to think it might be a cable fault.
Any thoughts on what is wrong and does anyone have the correct wiring diagram for my van that you could share.
Thanks.
Thanks.
