  • 14 Vote(s) - 3 Average
mpg indicator
Hi, my blingo has been indicating its doing 49.5 for a week now,,,how often should it change ?,,,ive reset the trip 3 times,,,but the mpg still is the same 49.5 ?,,am i doing somthing wrong ?.
thank Pat.
[-] The following 1 user says Thank You to Nomad for this post:
  • Brendan44
Well, that is the average mpg indicator and if your driving hasn't radically changed then I wouldn't expect it to change. The more miles you have on the clock the slower it will change because it's averaged over all the miles traveled as far as I know. Resetting the trip length indicator should have no influence. Doesn't on mine. I've got about 8800 km on the clock and mine is averaging 5.8l/100km and hasn't changed in quite some time.
Tom
thanks Tom,,,i see that it rarely changes,,ive done 1300 miles now and the mpg is now saying 50.4im hoping it will get better as the engine gets run in.
Pat.
Mine has done 20500k and has sat at 44.9mpg for a over a month now.
I DO MISS MY BERLINGO Heart
(13-11-2011, 11:32 AM)3rensho Wrote:  The more miles you have on the clock the slower it will change because it's averaged over all the miles traveled as far as I know. Resetting the trip length indicator should have no influence. Doesn't on mine.
Is that correct? Before I had the test drive last week in the 2008 Mk3 XTR, the computer said 6614 miles had been covered @ 44.9mpg and an average speed of 27mph. The salesman reset the fuel computer, iirc by keeping the toggle switch on the end of the right hand stalk depressed for 4 seconds. At the end of my drive when I toggled through again it said 10 miles @ 50.4mpg and an average speed of 29mph.
Colin
[-] The following 2 users say Thank You to reedx for this post:
  • daviddb, Nomad
yes mine changes every time, never stays at a set mpg. I push end in every tank fill up. If I go on a drive 30-60 miles, or a long trip say a few hundred miles I get 49.5mpg but for normal use around my village up and down mountain where I live [ normally 4 times a day] and back and forth to Bangor city, then it shows 42,6 mpg, which is what I would expect. The 1000ft climb on average 4 times a day sucks the fuel out.
Pete
2010 artic silver VTR with EXTRAS.......Confusedunny:
If I'm just driving in my local country area I can reset it & it will show up to 53mpg. If I zero it before a fast motorway run 70mph+ it can drop to 44mpg. Its worth experimenting if you want to save fuel, for example keep down to 65mph on the motorway & you can get 48mpg.
After driving to Ireland and back my Blingo averaged 53.1 best ive had yet!
(06-12-2011, 04:22 PM)philip Wrote:  After driving to Ireland and back my Blingo averaged 53.1 best ive had yet!
That sounds good. The best I can manage with my 2.0Hdi is 49.4, I just cannot get 50mpg no matter what I do.
Oh and thats converting liters to gallons as I dont have a mpg display.
remember the mk3 is a 1.6hdi and you have a 2.0hdi
eolys
Last Post: magoo1
Yesterday 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
